Dec 7, 2004 #1 T Tomrhzhang Guest How to edit the config.pro file in Pro/e wildfire?(system is win2000)
Dec 7, 2004 Thread starter #2 P puppet Guest tools-> options anything you change here saves to your config.pro, when u hit save. if you know what exactly you want to change or add, you can simply load up your config.pro in notepad and add/remove anything you want.
