How to convert Durometer Reading to a Stiffness for modelling in Nastran
MrIcu
Aerospace
Oct 8, 2016
Hoping someone can help me out here.
First the scenario:
We have a test set-up that I have to model in Nastran. As an oversimplification of the set-up, think of a simply supported beam on both ends. The supports are made of steel blocks topped with a 1/4" thick silicon rubber so that the "beam" does not get localized damage when a force is applied at the center.
I would like to model this in Nastran, but would like to include the stiffness of the rubber material so that I can get more realistic deflections and internal loading.
My plan is to introduce a GAP element between the beam, and the support/constraint with an initial GAP of 1/8" (since the rubber will never be fully compressed during loading. However, I have to give this GAP a open stiffness of the rubber material. The closed stiffness will be something high like 10e7.
The only information I have of this rubber material is that it has a durometer hardness of 67A. Can someone tell me (hopefully with insudtry references) how I can convert this durometer reading to an equivalent stiffness that I can use in my models? It doesn't have to be highly precise, but perhaps an average stiffness will work since I know rubber stiffness changes as the amount of force is being applied.
Keep in mind that I'm doing this to reduce the conservatism in my analysis. I could forego modelling the rubber altogether and get high stresses and larger deflections if I assume a hard constraint.
Thanks in advance for your insight and advice.
Well I'm sure you can google as well as I can. is the rubber bonded to the steel plate or just lying on top? The former is easier to model.
Cheers
Greg Locock
More important than the elasticity is the fact that such materials are essentially incompressible. The elasticity is highly non-linear.
My experience is that bonded rubber items produce very high shear loads when compressed if they cannot bend or otherwise distort.
Google result:
and
Ok maybe I'm just a really green engineer by asking this ... but I have stumbled onto those google searches and all I can calculate is the Young's Modulus (E) which has a unit of pressure.
Nastran stiffness is not given in units of pressures. It is in units of lbs/in or N/mm. So my follow-up question would be if I only had the durometer hardness of 67A ... I can calculate the Young's Modulus using the equations that google can give me ... but how do I convert that to a stiffness?
The rubber is essentially laying on top of a steel block ... all being held together with good ole duct tape all around.
If you have Young's Modulus for the material E, you can calculate the unit strain e (dimensionless because its units are in inches per inch) for a given stress σ using the relationship E = σ/e. If the thickness t of the neoprene pad is known and the bearing pressure σ on the pad is known, the deformation is e.t which is equal to σ.t/E.
BA
Tmoose - very interesting info. Thanks.
