MrIcu
Aerospace
- Oct 8, 2016
- 2
Hoping someone can help me out here.
First the scenario:
We have a test set-up that I have to model in Nastran. As an oversimplification of the set-up, think of a simply supported beam on both ends. The supports are made of steel blocks topped with a 1/4" thick silicon rubber so that the "beam" does not get localized damage when a force is applied at the center.
I would like to model this in Nastran, but would like to include the stiffness of the rubber material so that I can get more realistic deflections and internal loading.
My plan is to introduce a GAP element between the beam, and the support/constraint with an initial GAP of 1/8" (since the rubber will never be fully compressed during loading. However, I have to give this GAP a open stiffness of the rubber material. The closed stiffness will be something high like 10e7.
The only information I have of this rubber material is that it has a durometer hardness of 67A. Can someone tell me (hopefully with insudtry references) how I can convert this durometer reading to an equivalent stiffness that I can use in my models? It doesn't have to be highly precise, but perhaps an average stiffness will work since I know rubber stiffness changes as the amount of force is being applied.
Keep in mind that I'm doing this to reduce the conservatism in my analysis. I could forego modelling the rubber altogether and get high stresses and larger deflections if I assume a hard constraint.
Thanks in advance for your insight and advice.
First the scenario:
