bxbzq
- Dec 28, 2011
- 281
Take fig 7-54 in '09 std as an example, the four holes are treated as two separate patterns. If I want each hole to be controlled separately, how do I specify on the drawing?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Of course, it wasn't specifically about fig. 7-54. It was about a case where there are so many features to be controlled separately that associating size dimension, positional feature control frame and SEP REQT note with each and every hole can be really painful. That is why I suggested to go with tabulated tolerances. And it is not my job to judge whether you can read (with comprehension) or not, so I am choosing to stay as far away as possible from this part of your comment.CH said:I can read as well as JP and I have a copy of 2009
When you mentioned "20 or 40 holes", did you mean Fig.7-54, because I don't remember it having 20 or 40 holes.
So far you have not proved that the idea is flawed (at least your graphics have not done it), so let me show you that the idea does make sense, i.e. there is a geometrical difference between considering features simultaneously and separately. In the attachment you will find a modified version of fig. 7-54. For simplicity I just considered 2 holes, not 4. I also added geometrical tolerances to datum features B and C to make the proof possible. To keep pictures clear, I used axis interpretation of positional tolerance at MMC.CH said:This makes me think you were talking about applying SEP REQT in general, and in general the idea still flawed.
You are right, I didn't have to make it 2 paragraphs. My apologies.CH said:1. Yes, I missed MMC on my position; I do not always have time to proofread when posting from work.
2. Same as 1. You didn't have to make it 2 paragraphs.
Like Evan said, using datum targets significantly reduces instability of a part, but this is not what my comment was about. I clearly said that in case of your both drawings (where datum targets have not been used) the difference between the prints is possible. And I provided a brief description of when this can happen. If you think it is not true, constructively prove it. But please use entire surface as primary datum feature, not just some portions of it.CH said:3. Borderline demagoguery. "What if" is not an argument. What if datum A is represented by 3 target points so the same part is always restrained exactly the same way?
pmarc said:please use entire surface as primary datum feature, not just some portions of it
This actually proves that your understanding of the whole "instability-when-SEP-REQT-is-specified" concept is wrong. There is indeed no need to re-fixture the part, BUT if you are not able to find your best candidate datum (so that axes of both holes fall into their positional tolerance zones simultaneously), you are allowed to re-fixture it in order to fit the holes into their positional tolerance zones separately. If SIM REQT was specified, the re-fixturing would not be allowed. And the very same logic applies to situation when datum features are specified at MMB and actual geometry of a part allows for datum feature(s) shift.CH said:My argument was that you will not wobble the datum indefinitely, once you found your "best" candidate datum there is no need to re-fixture the part.
Nobody has to build 20 or 40 fixtures.CH said:In your example with 20 or 40 holes nobody will build 20 or 40 fixtures or re-fixture parts 40 times; they will build 1 fixture with removable pin or pins and clamp the part down just once as soon as suitable position is found. Not to mention that all 40 holes will be definitely machined at once, from one single fixturing.
I already answered to that argument, so here I will simply paste what I wrote on 5 May 14 7:35:CH said:Not to mention that all 40 holes will be definitely machined at once, from one single fixturing.
Isn't defining a looser relationship between holes a benefit from functional and especially from manufacturing point of view? Isn't the additional possibility to verify each hole separately a benefit from QC point of view? Especially in cases where simultaneous verification does not give positive results? This was already said (not only by me), so again I have no idea why you are saying that nobody answered to your question.CH said:This is what I started with my very first post: what are the actual benefits from functional, machining or quality control point of view? What is the point of using technique that even experts will disagree about? Nobody answered.
No, I disagree with that. SEP REQT can be applied even when datum feature shift is not present. Fig. 4-41 in Y14.5-2009 shows how this is possible. Generally, all depends on geometry of a part and configuration of its datum features. In case of fig. 7-54, for example, datum feature shift will be not present only when datum features B and C are produced at their MMBs at the same time. This is quite unlikely to happen in reality, don't you think? And in case if you still believe that the application of SEP REQT is limited to very special cases, think how similar MMC modifier after geometric tolerance value works. Bonus tolerance will not be present only when a feature of size is produced at its MMC size. When the size departs from MMC, we can take advantage of that. Why not to take the very same advantage of presence of datum feature shift?CH said:And by the way, do you agree that practical application of separate requirement is not universal, but only useful when datum shift is present? (Counting datum wobble as logical subset of datum shift)
