MarkCopland
- Nov 28, 2003
- 29
How to constrain a closed ring beam element for 90, 180 degree symmetry cases under external pressure.
I need help to define the following simple constrain beam case
I got a “circular closed ring” with a square profile 25x25 mm and an mean radius of 518 mm, material steel, the ring is has a external pressure of 100 N/mm2 as example.
I would like to simulate this case using a FEA software, as a 1D beam element.
But I would like to use 3 different constrains sets (case A: 90 degree, case B: 180 degree symmetry) and case C: the full 360 degree model.
My intention is to compare results for buckling pressure values, (so I took this 3 cases to evaluate non symmetrical buckling cases -90 and 180 degrees- with regards to the 360 full model.
My question is how to set the constrains for this 3 cases.
Any help will be welcome
