how to change LC 3015BIIINT language settings
If it's the newer control it's just a parameter.
If it's the older AMNC control (just the touch screen panel) it needs a firmware update (very difficult)
If you already bought it then you might need to learn Japanese, it's probably easier than getting the firmware files.
Thank you very much. Do you know scale percent between n2,o2,he into mixture gas?
Nghia
hi, i have a LCG 3015 CO2 laser with a AF3500i-C resonator. The gas mixture is 5% CO2; 60% He; and 35% N2; but if you want to know the gas type used for cutting, then 1,2,3 are for oxigen cut, 4 is for nitrogen cut and 5 is for air shop cut
7 is use for high pressure nitrogen where you adjust the pressure with a dial usually for anything over 7kg.
Dear all,
Please guide me install amnc laser on amnc pc of laser lc 3015 biiint.
Nghia
