How to calculate the pump surge pressure?
SyedZainAli
27
Dear All,
I am right now looking for some pumps attached in parallel to a header I want to calculate the surge in startup of pump to cater the hammering in the header
Syed, I don't think there is any easy way ro do this other than a full transient analysis. There are so.many variables it is not easy to calcualte.
Is this anexkating Pdroblem or anew set up?
Install a pressure transmitter on the pipe and data log the pressure surge. You will need a data logger that is capable of recording instantaneously, not one that samples once per minute.
The data loggers are not expensive:
You might also investigate soft start systems for the pumps.
What type of pump and what power rating do the pump's have.
Sounds like you're starting a pump against a low head. Try changing the start sequence and start against a closed valve.
Rather than trying to assertion surge pressure on start, you should be investigating how to reduce surge pressure.
Would suggest more detail is required for meaningful answers.
