pumped flow creating negative pressures to eliminate small pump
swazimatt
NZ
I was recently tasked with designing a small leachate pumpstation servicing an odour control biofilter. The static head is quite low at about 3m that discharges to a terminal pumpstation that receives pumped flow from multiple other wastewater pumpstations.
I got thinking that if i connected a rising main from the leachate wetwell into one of the other rising mains with a y-junction and a low head non-return valve (like a wastop valve) would the flow from the pumped pipe across the junction create enough negative pressure on the leachate pipe that it doesn't require a pump in the leachate wetwell? (in this configuration the static head could be reduced to 2m, possibly less, leachate pipe would be about 20m.
In theory i think this could work and just curious about it as i have already finished the design. but not sure how i would even calculate this. It may only work if the velocity in the pumped main was massive.
Chatgpt says no :-(
🔧 Why It Might Work:​
  • When a high-velocity flow moves past a side branch (like at a Y-junction), it reduces static pressure at the junction (Bernoulli effect).
  • This drop in pressure can create suction on the side arm—if the main flow is strong enough.
  • This is the same principle behind how some chemical eductors and vacuum generators work.
🚧 Why It​
  1. Rising mains are pressurized systems.
    Unless flow in the main is very fast (creating significant velocity head), the pressure at the Y-junction is typically positive, not negative.
  2. Y-junctions don’t provide strong suction.
    The negative pressure created is often small and localized—rarely enough to lift liquid even 0.5 m, let alone 2 m.
  3. Non-return valves (e.g. WaStop) are designed to prevent backflow, not to act as suction-inducing devices. They add resistance.
  4. Backpressure from the rising main can block flow from your leachate pipe unless there's a higher driving pressure behind it (usually a pump).
It could possibly work , ultimately Bernuolli is your friend here. If the velocity goes very high, the pressure goes low. This is the principle behind venturi vacuum devices, hydro-ejectors etc. Google "Venturi" and it will make sense. The principle is to massively increase the velocity in a small location, then reduce the velocity after (usually done by reducing the pipe diameter in a small section. You plug in the suction line right into the middle of the venturi high velocity / low pressure zone.
From a calculation point of view, it's streamlines and Bernoulli's principles. Need to generate a ow enough pressure in the venturi, so that the leachate line has enough pressure difference to achieve the required flow
the "but" is
- it's not "free energy", sitll need the same amount of energy to move all the fluid
- Now have to deal with a high wear component
- More difficult to control (not sure if flow rates are critical in this application)
The pressure at the junction will be positive and flow will be towards the biofilter.
Only way to reduce pressure at junction is to increase velocity enough to cause a vacuum by reducing the flow area at the junction, This will cause a high pressure drop in main line and introduce undesirable complexities. What you proposed I never seen done and would not try it. Eductors are used only in special applications.
You need some form of venturi to make this work.
OR just stick your leachate tank 3m above the pipe?
What is your required negative pressure to induce such flow, and what is the vapor pressure of the fluid? Is the negative pressure sufficiently high to open the one-way valve, while simultaneously being sufficiently low to not induce phase change in the fluid in question?
Pumped leachate injection should be top entry into the main, so that waste water solids dont accumulate / reverse flow in this leachate line and bung up the check valve.
it is basically water, and i would say minimum negative pressure would be about 3m (assuming leachate suction pipe is low velocity)
so it seems that the theory has merit (eductors use it!), however as Andrew said, it is not free energy, there would eb a loss somewhere and existing ww rising mains are also not really ideal to add diameter restrictions to
thanks though, it has been a fun topic.
It won't work as is. I will write a detailed answer on how to make it work soon.
Can you please confirm the diameter, Press and velocity of water in the main pipe at the junction?
