How to calculate the clamp connection? 1
SJEC
Petroleum
Jun 21, 2004
41
I am working on a 60 years old heat exchanger.
The client want rerate it to higher operating pressure.
However, it use clamp structure instead of girth flange see attached drawing for details.
I can not find any calculation method for this structure.
The only clamp calculation method is ASME Sec VIII div 2 4.17. however the structure is not exactly the same.
Is here anybody have experience to deal with it?
Thanks in advance.
For accurate result you can use Finite Element Analysis like solidworks Simulation for doing the FEA of the clamp.
Aldrin Salvatierra
Mechanical Engineer/Lead Designer
Solid Engineering PH
SJEC....
There comes a point in the plodding progress of industry when you simply "gotta buy a new one".
Someone has to take a stand, no matter how many 25 year old MBAs are screaming "makeitwork, makeitwork, makeitwork"
Reworking and uprating 60 year old equipment is a gamble.
Will your MBA boss taking financial responsibility in case there is a catastrophic failure of this ancient heat exchanger under the uprated conditions ?
Or will you be blamed ?
Is the higher operating pressure/operating temperature greater than the MAWP/MAT listed on the HX metal tag bearing the ASME/NB symbol and number?
Years ago the ASME guy convinced me a vessel could not be restamped; maybe that changed?
No, it has not changed. The vessel will not and cannot be re-stamped by ASME, it will be issued a new nameplate under the National Board Inspection Code or API 510. ASME B&PV Code is a construction code and once the vessel leaves the shop, it comes under API or NBIC for in-service inspection, repairs and alterations.
