How to calculate J and Cw for non-standard shapes? 2
orreng1
7
I have an inverted "T" shape and I need to calculate the J and Cw values. I donot have quick access to the Roark Book, as I understand it is in there. Does anyone know how to do this?
For a "T" shape where
b = width of the flange
tf = thickness of the flange
h = height from the tip of the stem to the mid-height of the flange (d - tf/2)
tw = thickness of the stem
J = 1/3 x ((b x tf^3) + (h x tw^3))
Cw = 1/36 x ((b^3 x tf^3)/4 + (h^3 x tw^3))
So a verification -
Let b = 4
tf = .5
h = 6.25
tw = .3
Then I get J = 0.2229
Cw = 0.2387
Cw = 0 for small thicknesses
thanks for the quick reply.
Is a "T" value valid for an inverted T?
Also, I thought the values depended on a "mesh", or matrix...?
Guess I really don't understand how these values are derived.
I would ignore the effect of Cw. It (torsional warping) will contribute a trivial amount to the capacity. All the torsion will be taken by the St. Venant's stresses. If you have to enter a value for a computer program put in .0001 in^6.
My beams vary but on average are 30" high, web is 3" and flange is 6" x 2". Thinking I should not iognore it for this. What about the inverting of the "T"?
I would still ignore this effect. The mechanics of torsional warping is very complicated, but an easy way to simulate for an I-beam or channel it is to place equal and opposite horizontal forces of T/2h (where h is the distance between your top and bottom flange). Then analyze the flanges for weak axis bending for these forces.
Now if you try the same thing with a T-section, there is no opposite flange to create the couple that can carry the torsion. Even with your beefy section, the warping will be a small effect.
J and Cw are independent of orientation (T vs. Inv. T)
Thanks people, I really appreciate the input. It helped to clear the muddy water on this subject.
Check the slenderness ratio of the elements composing the T. To use the 1/3 factor in the calc for J the width/thickness ratio for the element needs to be greater than 10 (theoretically infinity). I don't have my book with me right now to verify the actual numbers.
Does anyone know what the generalized form for Cw is for any arbitrary shape? Or could anyone perhaps refer to a good text which describes this?
I find all the given formulae for various shapes fine and dandy, however I would like somthing more along the lines of a derivation.
