I would still ignore this effect. The mechanics of torsional warping is very complicated, but an easy way to simulate for an I-beam or channel it is to place equal and opposite horizontal forces of T/2h (where h is the distance between your top and bottom flange). Then analyze the flanges for weak axis bending for these forces.
Now if you try the same thing with a T-section, there is no opposite flange to create the couple that can carry the torsion. Even with your beefy section, the warping will be a small effect.
