The relative downstream pressure is almost zero , because the lines converge to the reservoir.
This would mean that delta P is the whole pressure I measure right after the pump, which is set by the pressure relief valve. And it would not depend on pipe diameter.
But if I reduce the pipe diameters, I would see a reduction of flow rate. And if I increase the diameters, delta P would decrease.
I'm a little bit confused....
