How to caculate heat gain for a lift ?
HuyLee
Industrial
Hello everyone
Today i want to discuss about a problem that is how to caculate heat gain of a lift. I am making a BEM for saving energy. I should determine each part of the elevator (motor, control, light ... ) to caculate heat gain or We may have any solution for this. Can i have your advices, thanks you
Do you mean the energy expended by the lift motor or pump or the heat gain of the lift compartment itself?
I mean the heat gain of the elevator that impact to the cooling load
What data does manufacturer provide? Sometimes they provide a cooling load number that takes into account typical operation or the average of a ride.
Your cooling load basically is a function of electricity used at operation (up or down) and how often it is expected to operate, and what standby consumption is.
Whatever energy is supplied to the lift will ultimately be converted to heat load.
You may monitor the currents for individual equipment (possibly with temporary ammeters where required) and arrive at average currents with time. With this you can estimate the average heat loads.
Most of the heat will be the motor. Is that inside or outside of your building load?
Also usage has a huge impact as a stationary lift does no work or output heat
Why bother? Passengers will not be in the elevator long enough to complain. Remember, that the elevator cab is open to conditioned spaces at each stop.. Just delete the cab AC unit as it is not worth it (unless the client calls for it).
