How to analyze the load capacity of structural plywood (5-ply) on 2x2" square joists 24" o
CathyChuk
3
See the link below for the pdf on the properties of structural plywood. Hopefully the highlighted part shows up, indicating the plywood of consideration. Thanks guys.
I'm sorry, but what exactly are you asking?
How exactly would I determine the load capacity of the plywood supported by joists 24" separated. Should I use load-span tables or is there a method to calculate it by hand?
