how to adjust line thickness
emc2673
41
I know it seems I am asking a ton of questions but is it possible to change the line thickness of, say your dimensions, hatch lines, object lines when you go to print???
because right now all the lines are the same thickness
and my drawing looks cluttered
EMC,
Edit your config.pro file with this data
pen1_line_weight 2.250
pen2_line_weight 1
pen3_line_weight 1
pen4_line_weight 1
pen5_line_weight 1
pen6_line_weight 1
pen7_line_weight 1
pen8_line_weight 1
then you can tweek the line thickness with the number at the end.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
