How to add PMI from part file to master models assembly drawing? NX10/TC10
IvanNX
267
I made a part with PMI. I need to show some of these informations in assembly drawing, Is it possible and if yes how to do it? (design is in master model concept)
_____________________________
Enjoy your work and have fun!
I do not have access to GTAC, so if you can explain it.
And just fyi, I can see PMI in drawing model view (using filter to do that), but I can not place selected PMI it on drawing sheet, and that is what I would like to do.
see attached video.
Anthony Galante
Senior Support Engineer
NX3 to NX11 with almost every MR (24versions)
FOUND IT!
Drafting, select view, right click, Settings, PMI tab, enable PMI and set options what to be visible and in what view!
