The footnote to UG-45 refers to a material specification that does not use schedule weights acc. to B36.10M. In this case the specification's own 'regular' pipe weight should be used as the minimum thickness even when less than standard weight pipe.
This may be a stretch but can this be used for components such as hygenic tube & fittings that are produced to non B36.10 diameters and thicknesses. Fittings such as tri-clover and ASME BPE tube would be typical examples. In this application the nozzles are not subject to any external piping loads.
