Dear Jacksonfem,
You have the following types of dampings in FEMAP & NX Nastran Advanced Nonlinear analysis (SOL601:
1.- Damping from numerical integration: you can achieve it by modification of the Newmark time integration parameters (alfa=0.25 & delta=0.5). The previous default values lead to no numerical damping, and higher (stable) values introduces some numerical damping. These values are defined in the "NXSTRAT Iteration & Convergence parameters" window of the Analysis Set Manager for Advanced Nonlinear SOL601,129 analysis, not in the "Model > Load > Nonlinear Analysis", this menu is only for NLSTATIC (SOL106) analysis.
2.- RAYLEIGH DAMPING: these are alpha & beta damping constants, and they are ALPHA1 & ALPHA2 in the PARAM command. Parameter ALPHA1 dampens the low frequencies (and the rigid body modes), and parameter ALPHA2 dampens the high frecuencies.
The program computes the Rayleigh damping matrix from the
stiffness and mass matrices at the time of solution start. The Rayleigh damping matrix is not updated during the solution.
3.- LOW-SPEED DYNAMIC DAMPING: if activated, the solver includes mass and damping effects in the analysis. Again these values are defined in the "NXSTRAT Iteration & Convergence parameters" window of the Analysis Set Manager for Advanced Nonlinear Analysis.
4.- The use of Damper elements: concentrated dampers and springs with dampers.
5.- Physical damping: Energy dissipation material effects (plasticity) and friction.
Also, you have CONTACT DAMPING:
• Adds normal and tangential viscous dampers to all contact nodes.
• Set via CTDAMP parameter in NXSTRAT.
• Damping can act only in the first time step (CTDAMP=1) or remain constant through out the analysis (CTDAMP=2).
• If it remains constant, the energy associated with damping is output.
• Very useful for stabilizing static problems and removing high frequency oscillations in dynamic problems.
Please revise the NX NASTRAN Advanced Nonlinear SOL601 manuals, there you have plenty of information.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB:
