bigwilly104
- Aug 31, 2006
- 15
I have a 2/4 HP. GE motor that is part of a York commercial air conditioner. it runs the prop fan for the condensor. It is a sealed case motor with sealed berings. 208-230 1 ph with a 10/370 run cap. Insulation class B. This is a new motor. I am reading 190 deg F on the outside of the case with a wire thermister taped to the side. This is a air over motor so when I shut the unit down it will climb as high as 210 deg. This is the second motor I have had in the machine in a week and it is stil running. The first replacement motor lost the seal on the shaft end berings and got a bit stiff. I checked with York to make sure this was the same type of motor. Also the amp draw is 3.5 and the name plate shows 4.7 RLA. I cant get the manufacturer of the motor to call back GE is having a company called Regal-Beloit make the motors so tech questions go to them. INPUT PLEASE
