Ed, thanks for reply!
Material is too thin for acid clean. Material is slightly discolored (gold color), I will push back customer to try, otherwise I will have to scrap.
Pickling solution is mainly acid too (HF, HNO3 etc.), why do you think pickle can remove oxide, while passivation cannot?
By the way , this is custom 455 with >1% Ti that makes it very easy to be discolored. you cannot make the furnace perfectly with dry, pure H2. To remove TiO by anneal, say at 1000C, H2 need to be as dry as < -200F.
