How good is Sharepoint?
toffeet
Agricultural
Feb 23, 2006
190
We are in the process of evaluating different PDM software. Just how good and stable is Sharepoint with the handling and collaboration of CAD information?
Any comments will be greatly appreciated.
Solid Edge V18 SP5 on WinXP SP2
Depends on what you want to do.
Sharepoint/Insight is set up to be a departmental document control system. If you plan on using it for company wide data management, look elsewhere. Since you're running v18, you may want to give Team Center Express a look.
--Scott
For some pleasure reading, try FAQ731-376
Hi Scott,
Thanks for your response. Lets say I only want to manage design data and I want to present this information in a simple manner to other departments.
Solid Edge V18 SP6 on WinXP SP2
If you ONLY want to manage Solid Edge data (although some other can be thrown into the mix),
If ONLY your department is going to be authoring the data and maintains control of the Sharepoint database,
If you ONLY want to provide others with the ability to view your Solid Edge data through a web-type interface,
then Sharepoint/Insight will work for you.
But, if you want other departments to view in-process work, and have approval authority, and be a part of the work flow, then Insight will probably not be the effective tool you're looking for.
<Insert shameless plug>
If you need a consultant to look at your data and give a good recommendation, I can help further.
Of course, I'm always here at eng-tips to help as much as I can.
<End shameless plug>
--Scott
