If there is a building proposed to be built on the fill side of a newly proposed cast-in-place concrete contilevered retaining wall, how far back from the back side of the wall would the building need to be held to not load the proposed retaining wall?
The wall retains 9' of soil and the grade behind the wall is level.
The bottom of footing of the proposed building, located on the fill side of the retaining wall, is 2'-4" below grade, thus the distance from the bottom of the proposed building footing to the top of the proposed retaining wall footing is 6'-8".
The proposed building is a brick clad, wood framed, two story townhome building.
Thanks for taking the time to render an opinion!
