Hi All,
I have a question regarding bearing capacity. I work in the oil&gas industry designing what we call "pads" that support the drilling rig. I have calculated the max load appplied to the soil to be 18,000 psf or 125 psi. I ultimately want to know if my soils can handle the loads according to terzaghi's bearing capacity equation. We do not use concrete foundations but instead make a soil/cement mixture of about 8-12% cement content by weight to support the rig. I have taken core samples of these mixtures after curing with compressive strength test results ranging from 300-450 psi. the soil cement layer is usually 12-18" thick. Average CBR values of the in-situ soils beneath the soil-cement layer range from 10-20
My question is: Does the compressive strength of a sample equal the bearing capacity of the soil its taken from? I do not think so, given that the bearing capacity is derived from terzaghi's parameters and is based on a different failure mechanism. Maybe i am wrong and this is easier than I think. If not, then how can I determine the ultimate bearing capacity of the pad? Is it dangerous to assume that because the compressive strength of the core samples exceed the max load then the soil is adequate. Some people have said "psi is psi". I dont beleive that.
I am an EIT in my first job. I can get alot of data but dont always know how to interpret. Any help is appreciated. Thanks
If you need more information ill be happy to provide.
