I need some advice and clarification about specifying surface roughness and finish.
I've spec'd out a simple Ø.125" pin from 302SS, grand total of 1.750" long, with simple corner breaks to take care of burrs. Along the center of the pin, I put a simple leader and the familiar "checkmark" and 16 in the “elbow” of the check, intending to denote a 16 ?-in finish. No units or anything else. The print has a standard note that all dims are English unless otherwise specified. Now, a producer, a fairly reputable one, has sent a message back asking "is that surface finish 16" or 16mm?"
This scares me.........I don't know if I want parts produced by somebody even capable of fathoming a 16mm RMS surface roughness.....much less 16"....although it'd be an interesting paradox to see on a Ø.125" pin.
My actual question is how I should properly specify a 16 ?-in finish so that nobody gets all confused. The old draftsman here seems to think what I have is proper and sufficient, as does what I can decipher of Machinery's Handbook. I just want to be sure there's a consensus and not something I've overlooked.
Materials department (responsible for the quoting of the parts) thinks I need to do a revision of the print and give some sort of clarifying notes for the convenience of this potential supplier, but it seems unnecessary to clarify something that appears to be an established drafting standard.
All help is appreciated.
SW2007 & NX4
SW2007 & NX4
