pilesmakesmiles
We are working on a drainage investigation, a significant part of which involves calculating the flow capacity of a 100m long culvert beneath a road and some houses to see if it is likely to surcharge.
We want to determine the gradient of the culvert to verify someone else's guesstimate which seems quite steep compared to the fall of the land.
In an ideal world we would measure the level at the upstream end and the downstream end, the distance between the two and get a slope. Unfortunately there is no access to the upstream end.
We could start at the downstream end and measure the level from inside the culvert. Unfortunately the culvert is approximately 1m x 1m in section and had a bend every 5-10m so this would be very time consuming. There are no intermediate access chambers on the culvert.
Can anyone suggest any methods for working out the gradient of the culvert to a reasonable degree of accuracy?
