The filled surface end of the hole wont let me start a sketch(I assume that it's not a flat surface), so I started one at the opposite end of the part, where the hole begins. I sketched the circle, and extrude thru cut it, which resulted in a "tube" that extends beyond the filled surface, as if it extruded a "thin surface", although the thin surface option was not checked.
Any other ideas?
