MohammadB84
Bioengineer
I am in the process of testing a very heavy mechanical patient lift. The lift has to be placed on the surface of a sloped metal plate. The weight of my lift(load) is known (~ 1040 kg). The metal plate that i will be using is a carbon steel plate with the dimensions of 96"X60", but I am not sure what would be good choice for the thickness of that plate.
Unfortunately, I don't have any background in mechanical engineering but I am sure there should be a formula to calculate the maximum load a metal plate with certain dimensions can handle before any permanent deformation.
So as a summary, I would like to know how thick my carbon steel plate should be to handle the max load of 1040 kg positioned in the middle before it deforms permanently.
Sorry if I can not explain any better but let me know if you need more explanations.
Any help would be truly appreciated.
Mohammad
