sspence:
HV of gas = Sum [ (x1) (HV1) + (x2) (HV2) + (x3) (HV3) + ... ]
If your percentages are volume percents or mole percents (which are completely equivalent), then:
HVn = heating value of gas component n, in kJ/m3
x = (percentage/100) of gas component n
If your percentages are weight perecents, then:
HVn = heating value of gas component n, in kJ/kg
If you would rather use USA units than metric units, then:
Use Btu/ft3 and Btu/lb instead of kJ/m3 and kJ/kg
Also, be consistent. If you want the higher (or gross) heating value of the gas, then use the higher (or gross) heating value of each gas component. If you want the lower (or net) heating value of the gas, then use the lower (or net) heating value of each gas component.
Milton Beychok
(Visit me at www.air-dispersion.com)
