How Commutating valve works
thought2007
Aerospace
IN
Hi guyz,
I wanna know functioning & application of Commutating valve.
Thanks before
with regards
John
I have only ever seen them used in pipe flushing systems and reversing flow to backflush filters.
Sorry...can't help more than that...
That's a new one to me. What is a "Commutating Valve?" Is there other names for this valve that I might recognize?
Bud Trinkel, Fluid Power Consultant
HYDRA-PNEU CONSULTING, INC.
Some examples of commutating valves are the valves in geroter motors and valves in radial piston motors. These valves connect the pressure and tank ports at the correct time. Some are radial seal and some are face seal designs. The face seal can take up some wear if pressure balanced, but can be a problem if quick pressure changes occur. Radial valves require a close tolerance fit between the two parts. Both types require accurate location of the ports and will not tolerate contamination.
Thanks Ed for the clarification. I had never heard these valves called that or have lost it in my old memory banks. Seem to do a lot of that any more.
