I presumed that you want to change the colors of the lines in the draft environment.
1. Select Format>Style, the Style Dialog box will appear.
2. Choose ‘Line’ from ‘Style Type’ drop down list.
3. Select ‘Visible’ from ‘Styles’ list.
4. Click on the ‘Modify’ button.
5. From the ‘General’ tab of ‘Modify Line Style’ dialog box you will able to change the color.
Yes I want to change the colors of lines in draft enviroment. Once by once I know how change, like you teach, but I want know how get to change the all linetypes colors at once. It is possible? Thanks for FWC anyway.
first make a NEW line style almost as discribed by fwc
2. Choose NEW give it a name "Visible Red" based on "Visible"
3. From the ‘General’ tab set the colors.
4. Close the new linestyle.
5. Select de Drawing View.
6. Properties (RMB)
7. 'Display'tab and select the "Visible Red" in the dropdown list.
BTW in assemblies you can give individual parts a different color.
