How can I close an application from Excel
RayfromIntech
CA
I have an external application that I can start using the shell and path function. The application runs in my system tray.
I want to create a button in excel that will activate a macro that will stop this application.
I dont know the syntax or the proper function to use.
For example the program I want to stop is called Update.exe
When it runs, it is only in the tray at the bottom right of the screen.(It's not a minimized window) The path for this is C:\datalog\update.exe
Now how can I tell a Macro in Excel to stop and exit this application. A solution word for word would be nice.
Thank you to all.
Not very elegant, but you could use the "sendkeys" method. This basically mimics keyboard strokes, it takes a bit of fiddling to get it right, but it works. Its a way of automating applications that don't have any inbuilt programming language. Theres quite a bit about "sendkeys" in the VBA helpfile along with an example using the windows calculator.
Best regards
finnigan
