how can i choose a pneumatic press for my project ?( please read Description)
M.Abdollahi
IR
Hello guys.
I want to buy a machine that assemble mist pump spray or pump spray.i don't need a production line and i need a machine or tool that can assemble components of a pump spray manually or by human not automotional. i do some research and i realize that a pneumatic press or a manual_hand press can help me in this project but many of them are out there.
i need to help me to find what pressure and velocity is sufficient for my work and how can i get that? by a book ?by an equation? if answer is by a equation,how can i extract equations for this case?....
and if you have another suggestion for my project, i will be very happy.
besides, i attach a CAD PDF of my project and some dimensions of my pump spray.
Thank you so much.
 https://files.engineering.com/getfile.aspx?folder=f51ec731-69c3-4d73-90f7-e76e1dabbd3b&file=assembly.PDF
Press force is dependent on a number of factors. Dimensions. Tolerances. Surface finishes. Materials. Etc.
You have articulated exactly zero of any of these.
If you have the components already, just test about 100 of them.
I think any sort of arbor press, drill press, or pneumatic cylinder would work.
I would put a travel limit stop on the assembly jig then the pressure is not such a critical issue.
