Hi Everyone,
I'm working on a hot water plant design but the client instructed us to associate this design with a heat recovery system which is available due to compressor helium cooling.
So we did as asked and we link two hydraulic loops directly on the cold line of the main loop, as show in the drawing below.
my concern now and after reading little bit about it, is the Hydraulic separartion of those two loops as i did not forseen any Hydraulic separator ( switch) on the design.
The cuurent layout i have is that the two brahces which goes to the Helium compressor exchanger are only 800 mm far from each other ( see screen shot from 3D below).
Do you think that this arrangement will have no issue to manage the hydraulic separation betwen the two loops?
Thank you in advance for your help.
