NathanielBabiak
(I've never posted before, but have found this forum to be quite useful. I've been doing facilities work for about 9 years now, and just moved into pipeline. I've already searched the site and haven't found anything relevant.)
I have a question about horizontal directional drills post-installation. Specifically, about the residual stress on the bent pipe string. I read the 1995 edition of PRCI PR-227-9424 available in Technical Toolbox and also David Willoughby's HDD book. Both take care to show that this consideration is significant, but check for code compliance with B31.4, not B31.8. I'm not sure how to check if an HDD design is compliant with ASME B31.8, as this topic doesn't seem to be within the code's scope.
So here's my question(s):
Which paragraph in ASME B31.8 considers the HDD post-installation residual stress of bending?
As a follow-up question, how does this consideration compare a *design* stress or strain to an *allowable* stress or strain?
Thanks in advance,
~Nathaniel
Thanks in advance,
~Nathaniel
