End Face Dimension - ASME B31.8 831.4.2(j)(3)
engineer0
In regards to Pressurized Hot Tap Tee Reinforcing Sleeves, ASME B31.8 831.4.2(j)(3) states that "the face dimension should not exceed 1.4 times the calculated thickness required to meet the maximum hoop stress of the pressurized sleeve. The leg of the fillet deposited on the end face need not be carried out fully to the shoulder of the face if doing so would result in an oversized fillet weld."
Example scenario - 20" Existing pipeline segment with an MAOP of 395 PSIG is being retrofitted to accommodate In-line inspections. Pressure control fittings are being used to retrofit the pipeline. Class 3 location. Fitting properties are 50ksi yield, 22.625" OD. Header pipe is 60ksi yield, 20" OD, 0.267" wall.
Example 2 scenario - 20" pipeline segment previously rated for 395 PSIG was derated to 150 PSIG. New facilities being installed on the 150 PSIG segment will not be designed to meet 395 PSIG but 150 PSIG (maybe slightly higher but not as high as 395 PSIG); there's no need to rate it higher. New facilities are being tied in with a pressure control fitting. Fitting properties are 50ksi yield, 22.625" OD. Header pipe is 60ksi yield, 20" OD, 0.250" wall.
Question 1: When B31.8 states "calculated thickness required to meet the maximum hoop stress of the pressurized sleeve", should I be using pipe design formula rearranged to solve for t based on fitting properties? t=(P*D)/(2*S*F*E*T) In this case it's a Class 3 location, so in Example 1 it would be t = (395*22.625)/(2*50000*0.5*1*1) = 0.179". Then t*1.4 = 0.250". So the end face of the fitting should be tapered, beveled, or chamfered at ~45° to be between 0.179" and 0.250". The problem with this is that the fillet weld leg needs to be at minimum 1*t(header)+gap which is 0.267" wall. Unless the maximum hoop stress is supposed to be based on the B31.8 design pressure of the pipeline which would/could have been P =[(2*S*t)/D]*F*E*T = [(2*60000*0.267)/20]*0.5*1*1 = 801 PSIG. When the calculations are rerun for the pressurized sleeve at this design pressure, the wall thickness range of the fitting end face could be allowed to be between 0.362" and 0.507", which would make more sense when interpreting 831.4.2(j). The problem is worse in the second example scenario, I won't list out the calculations for now, but you can see the dilemma of not needing to design something to the maximum of what the pipe design formula comes up with based on pipe properties, seam, class location, and temperature. But if it's not to be based on what the actual hoop stress that fitting will experience, then that leads to my second question...
Question 2: What is the purpose of the end face not exceeding "1.4 times the maximum hoop stress of the pressurized sleeve"?
ASME PCC-2 is written a little more clearly for the design of pressure sleeves. Refer to Figure 206-3.5-2.
I would do your pressure containment calculations as you have for example 1. Note that that if your fitting has a long seam weld, your weld efficiency of that seam will be based on your inspection. I've seen folks take E = 0.8 to avoid inspecting that seam. That gives t_sleeve = 0.224" minimum.
For example 1, your minimum weld leg per 831.4.2(j)(1) is t_parent = 0.267" (plus any gap, typically 0.063"). And then your maximum weld leg and fitting end dimension per 831.4.2(j)(2) should be 1.4*t_parent = 0.374". The fitting should then be tapered to between 0.267" and 0.374". You could limit it to 0.314" to strictly comply with 831.4.2(j)(3), but I would just follow PCC-2.
The 1.4 factor is (as far as I know) just a reasonable value used to prevent oversized fillet welds. Somebody on the committee might be able to confirm if there is a more scientific basis for it.
