Also... a 'trick of the trade'... wherever a stress concentration occurs in a honeycomb panel or component...
The core is filled partially/discretely, or completely, with thermosetting potting compound. This is typically epoxy resin filled with glass or phenolic microballons or 'other low density/rigid fillers/reinforcement materials'... or are injection-filled with foaming [self expanding] epoxy/etc potting mixtures.
These compounds reinforce the filled honeycomb cell [added crush resistance] and rigidize the foil walls [from buckling/shear loads] and increase adhesion contact area and greatly increase resistance to moisture/fluids intrusion [filling voids and increased cell sealing].
Potting is invariably used at fastener [hole] penetrations with or without an embedded insert... and for areas that are machined 'thin/flimsy'.
Regards, Wil Taylor
o Trust - But Verify!
