AustinStructural
I am designing a 3 story project that utilizes Hollow Core Plank for the floor and roof system and light gauge steel stud walls for the bearing system. The lateral system is to be comprised of sheet steel shear walls.
I have no issue with the connection of the shear walls floor-to-floor, and the diaphragm to wall connection where the plank is bearing (span perpendicular to) on the walls. However, I am just not sure how to make the connection between all of the elements where the plank is non bearing (span parallel to) on the walls. If my floor was flat, then I would just tie the diaphragm in to the plates with shot pins, however, with estimated cambers up to 1.25" I just am not sure how to make this connection work economically.
I am trying to stay away from proprietary lateral systems here, so my intent is to make this work with standard SSMA sections.
Can anyone provide advice/details on how they have made this connection in the past and felt comfortable with?
Thank you
Thank you
