ron9876
- Nov 15, 2005
- 669
I have a project that is an older building with masonry walls and hollow core floor planks. The planks have openings for MEP services from the original occupancy, a proposed condo renovation that went bankrupt and now a new set for an apartment option. The cuts are excessive in some locations so I am looking for the best way to reinforce/support the planks. I have an underslung header system worked up where the condition is close to a wall and the primary issue is shear. But I have a few conditions where the problem is mid-span so I need a fix for flexural strength. I considered FRP but the planks don't have enough residual strength. So I am looking at adding reinforcing steel grouted in the existing cores. I plan to extend the bars at least a development length past the strand developement length. It all makes sense to me but it seems strange to have a plank that is prestressed for a ways then mild reinforced then back to prestressed. Does anyone see any problem with this approach. Thanks in advance.
