Hole wizard special holes
LOKi42
Is there a way to add custom holes to hole wizard. Like slotted holes?
Did you do a search here? It has been discussed before.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Why don't you just make those slotted holes into a library part and add them to your design library?
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
I took a quick look but didn't see anything. Ill check again
nothing comes up for hole wizard at all
That was a fast check.
Try "wizard". There are several.
There is not a slot option in HW.
Chris
FAQ559-1100
FAQ559-716
Use the search button below the thread title (between Forum & FAQs). It preselects the forum you are in for the search & I just got 20 hits.
If you use the main
button, you have to set the search parameters.
The best way is as Heckler suggested.
[cheers]
Making the best use of this Forum. faq559-716
How to get answers to your SW questions. faq559-1091
Helpful SW websites every user should be aware of faq559-520
