Kenneth, thanks for the clairification. I didn't have MIL-S-8879 so I wasn't sure what the "J" stood for (perhaps it was a bad example). My Global Engineering DMR didn't specify it was for aerospace only, hence the reasons for using quotes. Thanks again.
BBJT, I would have to say that SW does not dimension per standard, and (I have, sw99+) you should submit an Enhancement Request. The term "taped hole" is not even close to ASME Y14.5M, also, the leader is attached at a strange place.
Linqur, an easy work around is just to modify the text of your dimensions after. There aren't realy any links between dimensioned threaded holes and the model, at least none that I have noticed. Once I remember trying to change a course thread callout to a fine thread. I changed the drawing, but the model did not update.
Since I am reminded of this, me thinks it's time I doth submit again... "Happy the Hare at morning for she is ignorant to the Hunter's waking thoughts."
