M
mkzler
Guest
I have some metric holes that are dimensioned on the drawing using a note created in part mode. This is fine, but the hole dimensions are displaying with 3 decimal places like 5.000 and 12.000. I would like to change the decimals to 2 places like 5.00 and 12.00. When I try to edit the note in part mode, I am not able to modify this. This is a drawing that I have inherited from a previous user, and to be honest, I do not have extensive experience with drawing mode. Any ideas for how to correct this issue would be appreciated.
By the way, the note properties that I see in Drawing mode are:
{0:&Note_14:0}
The properties that I find for the note in Part mode are:
12X &METRIC_SIZE &THREAD_SERIES - &THREAD_CLASS &STD_HOLE_TYPE &VAR_THREAD &THREAD_DEPTH &NUMBER_SIZE DRILL ( &DIAMETER ) &VAR_DEPTH &DRILL_DEPTH
This is what is in the "note" box in the hole feature creation:
12X M3x.5 ISO - H TAP down_arrow_symbol 8.000 2.5 DRILL ( 2.500 ) down_arrow_symbol 9.000
Everything is ok, except that I would like all decimals to be to 2 places instead of 3.
Thanks a lot
{0:&Note_14:0}
Thanks a lot
