I would like to set where my History Data is being stored. At the current time it is stored on the network, I would like to add an environment variable to change this location. Is this possible?
You can't change the history palette on it's own, it's contained in the file history.pax which lives in your user profile.
Below is copied from the help:
Changing the default directory of user customization files
If you want to use user-defined customization files saved on your system, point the UGII_USER_PROFILE_DIR environment variable to the directory of the customization files. You can redirect the following configuration files to the directory pointed by the UGII_USER_PROFILE_DIR environment variable.
Crud, I was hoping there would be a specific for this one, I did read this, but was hoping for a special variable. Thanks for the feedback, have a great weekend.
