Greatone76
- Feb 2, 2006
- 64
I have an existing building built in the early 1900's (I believe) that has what appear to be wood roof trusses. They are spaced 13' o.c. and span around 48'. The typical truss is around 6' deep and the top and bottom chords are (6) 2x11's. Between them are webs that make an X at 45 degrees which are (8) 1x8's. The web members and chord members appear to alternate and be connected that way. When I first saw them I didn't want to consider them a truss due to the unconventional web configuration and tried to get the bottom chord carrying an attic load and top chord carrying the roof load to work, but they were no where close to working, so it would appear that they would have to work as a truss to work at all. So after doing a little searching I'm seeing picture of old timber truss bridges with this non conventional X web configuration. Has anyone ever encountered this type situation in a building. I'm still hesitant to look at it as a truss, but looking for input from anyone on my situation.
