From the figure, it looks like the two lower horizontal members would have no moments anywhere, just axial load?
Call the top member and the vertical member under P "the ell".
Call the middle member #2.
Call the lower member #3.
Equating the horizontal deflection in the ell at member #2 to the axial deflection in member #2 gives you one equation.
Equating the horizontal deflection in the ell at member #3 to the axial deflection in member #3 gives you a second equation.
Summing moments about the top left corner gives you a third equation.
That leaves you three equations with the unknowns being N2, N3, and M1. In this case, calculating deflections is the tedious part, solving three equations will be fairly simple.
Having solved them, sum forces horizontally to find N1 and sum forces vertically to find V1.
It would quite likely be a reasonable assumption to say that the axial deflection in #2 and #3 is negligle, but that doesn't give a lot of simplification.
