The
Australian Steel Institute publishes a brochure,
Seven Reasons, which I'll summarise here:
1. Earlier Occupation
Fit-out of the lower levels can commence much sooner because propping of formwork is not required
? Work can proceed on a number of fronts with steel construction
? Early occupation means you get a return on your investment sooner
2. Reduced Risks
? Reduced OH&S exposure
? Off-site fabrication
? Reduced on-site workforce
? Reduced delays due to weather
? Reduced on-site congestion
? Reduced truck movements
3. Larger Column-Free Space
? Larger column-free space is provided by the long-spanning capability of structural steel
? Architectural freedom is provided by the column-free space giving greater ?exibility to building owners and occupiers
? More attractive space is provided by the smaller columns that are typically found in a steel building
4. “Future-Proof” Investment
It is easier to make major changes to a building framed in structural steel.
? Beams and columns can be strengthened to take extra loads by welding on additional plates
? New ?oor penetrations can be simply installed
? Steel offers a light-weight ‘add-a-top’ frame which makes it an ideal construction method for expanding existing buildings in any direction
5. Technology
Extensive research over the past decade has lead to more economical steel framed buildings.
? Advances in ? re engineering have drastically reduced the cost of protecting a steel frame without compromising safety
? Structural design advances result in more economic designs
? Advances in computer aided design and drafting together with computer-controlled fabrication has improved both the cost and speed of delivering a steel solution
6. Sustainable Construction
Sustainability during the life of the building
? Long lasting and durable
? Easily renovated or refurbished
? Easily strengthened or modi? ed
? Extend vertically or horizontally
Sustainability after the life of the building
? Demountable and reuseable as a complete building or as individual steel elements
? Easily demolished
? 100% recyclable
7. Competive Cost
