I have some very highly loaded anchor bolts ("through bolts") in shear. The service load shear force is 32kips to the worst case bolt of an 8-bolt group. The bolts are "through bolts" through an 8" slab with a thick steel plate at both the top and bottom of the slab. The concrete crushing of the bolts in shear will be restrained by the top plate. (The bolts are shear-loaded from the top of the slab.)
I imagine that ACI 318 Appendix D will be too restrictive and will not provide guidance on this condition. Does anyone know of any resources which would provide contemporary limit states for highly-loaded anchor bolts in shear when the concrete crushing limit state is restrained by the top steel plate?
