High Voltage CTVT Transformer
petronila
Hello All,
I would like to know what European or American manufacturer could provide a 1000 KVA-Three Phase, Column Type Voltage Transformer With Primary Voltage 400 and Output from Cero to 6 KV. 50 Hz.
Thanks and regards
Petronila
ABB CAN PRODUCE SUCH TYPE OF TRANSFORMERS
there is a few very good factories in Europe. I can recommend you VA TECH Elin in Weiz and SIEMENS in Nurnberg. Also AREVA (factories in Duisburg and Gebze) and ABB.
But you have too know that all of them are full of orders.
P.
Are we really talking about a 1MVA instrument transformer? Or a small distribution transformer? With a variable output?
How about a proper spec as a starting point, or at least a little more care in writing the one presented?
image.php
Thanks Scotty, the transformer is 1000 KVA, 50 Hz, Input Voltage : 0,4 KV and Output will vary from cero to 6 KV, is not an instrument transformer is a power transformer and was thinked to fed a Test Motor Center in Order to perform No load and load test.
We know Phenix can manufacture it but we art in Spain and we need other alternatives.
Thanks again.
Petronila
