I need to determine the flow of dry air to atmosphere through a small tube so we can correctly set up a series of tests. The aim is to achieve near sonic velocity (say M = 0.9) at the discharge by setting an appropriate upstream pressure. Software available to me will not cope so I am using Fanno tables but the calculations (see attached) assume ideal gas, require lots of manual iterations and I am not sure I have done this correctly. Accuracy is important if we are to avoid sonic flow as we will not be able to detect this during the tests.
I would appreciate guidance from those with the right experience?
Inputs:
Dry Air at 20°C, Tube ID 7.66 mm, roughness 0.03 mm, length 6.0 m
Required:
inlet Press,
mass flow,
inlet Mach,
outlet Mach,
Outlet temp
Inlet Press to achieve sonic flow at outlet (My calculation suggests 590 kPag)
My first priority is an answer then I would like to understand how the calculation is done?
Dennis Kirk Engineering
Inputs:
Required:
inlet Press,
mass flow,
inlet Mach,
outlet Mach,
Outlet temp
