Sorry I can't answer this, but who ever does will need to know what application you are using the material in. Is the material being loaded, oxidizing environment, etc. Please give us some more details.
If you can use a cast component then it can be ASTM A 297 Grade HU. If you need in a rolled form which you can fabricate it then Inconel is advisable. Hope this helps.
