I have been researching materials for use in a marine fastener application, but could use some input from some of you with experience. We have a part with a socket hex drive and 3/8-16 UNC thread and a mating square captive nut. The parts will be completely submerged in seawater for most of their life. The nut in particular is captive in a closed pocket where seawater will likely collect and become stagnant. I believe this will create a significant risk for crevice corrosion. High strength is required for these components in the range of 80 ksi yield or better.
We have used monel 400 or 500 for similar applications but there have been reports from our production staff of the hex drive stripping out easily during assembly. I am thinking this phenomenon is limited to the 400 alloy since it is not as hard, but I don't know because our drawing allows fabrication from either.
We have also used Inconel 718 for similar applications and I am leaning toward using it for at least one component here. I am concerned about galling between the nut and bolt. These parts may be disassembled on a monthly basis and I don't want them to lock up. Is there another comparably strong and corrosion resistant material that would work well with 718 for the mating part? We have used Nitronic 60 and Ni-Al-Br to prevent galling in the past but I don't think either is suitable for this application.
Also of note, we need a way to assemble these components so that they will resist loosening from vibration. Threadlocker seems like a good solution so I don't think lubricating the threads is an option to prevent galling.
